Home > Technical (L322) > HELP URGENT
Page 2 of 4 <1234>
HDC = Hill Descent Control
Post #136253 16th Aug 2012 4:18pm
Have you tried wiggling the gear stuck to ensure its in park! One of Gaz's fav things to try. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #136255 16th Aug 2012 4:20pm
+1 for the battery.
Either very low charge or u/s.
Caun you persuade anyone round about to jump start the car for you.
Another battery connected to your car should allow you to turn the key.
Post #136256 16th Aug 2012 4:24pm
STEVE57
England 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
low voltage.low battery??????? 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #136260 16th Aug 2012 4:36pm
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
when i went out to her this morning notised the brake lights were lit she started fine about eleven oclock, had to do a ten mile run so when i got back started to have a look ,thats when i tried the other key nothing but my concern is the brake lights being on whith no key in and it being locke up
been in touch with land ranger sevices in stockport he say bat and poss key lost its memory to car.
any more advice more than welcome have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #136269 16th Aug 2012 4:48pm
trainmanone
right guys update: striped down consol and tried the key ,with a wiggle and jigal the key turned stearing colom moved and she started, shut her down tried again and the same thing wont turn so have discounted key lost memory, and bat volts, looks like ignition switch/barrel problem.
still have problem with brake light on so could be conneted issue.
any more help most welcome
pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #136287 16th Aug 2012 5:55pm
Crumbs muck etc gets into the ignition barrel, you could try blowing it out with an airline
Post #136289 16th Aug 2012 5:57pm
i thought you had done that already Rolling Eyes ....brake light could be a stuck pedal switch.. ... - .- -.
Post #136290 16th Aug 2012 5:59pm
trainmanone
hadent striped down the consoll then ,have undon the two screws that hold the barrel thats when the key moved but not been able to do it again but im getting there need to remove switch and barrel noe to clean it up ,how do i get it out ?
brake light is ok when running so dont think its the switch ,think its a differant issue tbh
Post #136291 16th Aug 2012 6:16pm
autobiorob
England 2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
I had this problem with the key and a few places couldn't solve it. Believe it or not the previous owner had spilt coke over the console and barrel etc. and it had never been thoroughly cleaned up causing a sticky film over connections. I had took it to places and they put all the machines on to tell the problems but there isn't a traceability setting for spilt coke so sometimes its not the obvious. Cost me hundreds to not solve it but only £50 charged to clean it up properly. No problem since........fingers crossed! Once a Blue, Always a Blue
Post #136297 16th Aug 2012 7:20pm
trainmanone
update 2, ignition swich/barrel taken off car switch cleand but barrel kaput so think have solved that problem ,
now just the brake light issue ie they are lit when no key in ignition or foot on brake ,have disconected bp switsh and still lit so switch ok
Post #136343 16th Aug 2012 9:22pm
trainmanone
Update 3 ignition barrel and swich all re stripped and cleaned and put back together seems to work now but not tried on car as too dark now Sad .
have had to leave battery disconected as bloody brake lights still lit even with no ignition switch in Sad Crying or Very sad ,
any ideas as what to do about this issue , have tried disconecting the foot brake switch with no joy Crying or Very sad .
Post #136372 16th Aug 2012 11:18pm
Pete
Is it all three brake lights or just the high one? Might be a relay sticking. Have you hot rave to look at the wiring diagrams? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #136381 17th Aug 2012 7:41am
trainmanone
hi rob ,yes its all three had a look at diags but cant make head nor tail of them.
like i posted earlyer someone on another site had the same problem even down to ignition switch not moving and not being able to get the key out so i think both issue are related will find out in about a half a hour if car will start
Post #136385 17th Aug 2012 8:08am
Can anyone confirm that when a brake switch is disconnected as to whether the brake lights should be on or off?
Post #136391 17th Aug 2012 8:37am
Page 2 of 4 <1234>
