![]() | Home > Technical (L322) > Front Suspension Depressurising |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
Before I get on to my question a BIG THANKS to Joe90 |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
I thought there was only one block and both sides connected into it |
Thats what I thought but I dont have the block.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
WTF ! |
But the question is can I still deflate the air spring without it and WITHOUT stabbing it with a knife? |
Yes, as Meerbusch says, if you can get a 12mm spanner on the nut at the top of the airspring and turn it enough to allow a trickle of air out, then wait a good while for all air to leave the spring. Battery disconnected (best) or minimum air compressor fuse removed, of course!
Looks like your car has been...Tangoed |
What's a t-w-a-t-o? .
The car has been Tangoed and is ![]() ![]() |
Cheers for all the replies |
Bob, can you not trace the pipes and see if the valve block has been relocated (which I doubt).
