Home > Technical (L322) > Battery or alternator problems?
If you suspect you have battery or alternator problems This is an inexpensive but useful voltmeter to allow you to simply check where the problem might lie.
Plug it into an accessory socket with the engine off and you will read battery voltage. ( Depending on whether your sockets are permanently live or ignition controlled you may need the ignition on)
Leave it in overnight and read again in the morning and you can determine any voltage drain from the battery.
Plug it into an accessory socket with the engine running and you will read alternator voltage.
Takes a lot of the guesswork out of where the problem actually is.
Post #137731 25th Aug 2012 9:30am
certainly a nice clean way of checking... ... - .- -.
Post #137732 25th Aug 2012 9:32am
Also, if you suspect that your battery or alternator is not working correctly you can use the in car diagnostics to see what the voltage is and how its charging.
Simply use the 753 hack and go to vehicle signals screen. Discovery 4 HSE
Post #137743 25th Aug 2012 10:30am
Does that apply to all vehicle years?
Post #137766 25th Aug 2012 1:15pm
And also http://www.fullfatrr.com/wiki/Secret_Codes
for 02-05 number 9 on the list.[/b] .
Post #137767 25th Aug 2012 1:19pm
Thanks for that. Thumbs Up
Easier to plug a voltmeter in. Laughing
Post #137769 25th Aug 2012 1:25pm
