Home > Maintenance & Mods (L322) > 6 pot brembo |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
i believe mick [joker] has the same thoughts re this mistake..... ... - .- -.
29th Aug 2012 8:43pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
+1 for "this mistake" mine are far worse than my old 2003 FFRR and way behind the wife's D3
29th Aug 2012 8:59pm |
Bigkev Member Since: 20 May 2012 Location: Cheshire Posts: 37 |
If these will fit, then I think it is a case of the calipers, disc, pads and possibly the flexi hoses but possibly the hoses are a standard thread, although braided hoses may be a worth while upgrade.
29th Aug 2012 9:09pm |
What you need to check is weather the holes in the casting (hub carrier) are big enough for the calliper mounting bolts to mount the Brembo callipers...
29th Aug 2012 9:13pm |
Craig,
29th Aug 2012 9:20pm |
You can change the hub carrier for the 10MY onwards and then they will bolt straight on... £265ish per side... I priced them as an option...
29th Aug 2012 9:27pm |
So as mine is a MY10 they should bolt straight on?
29th Aug 2012 9:40pm |
You may be able to get away with carriers made up to fit them but they may not sit right.. As above, or maybe find a slightly older smashed up one and get the hubs and setup off that FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
29th Aug 2012 10:01pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2516 |
I'd want to be sure that nothing else was different (master cylinder, ABS set-up, bias etc.) before bolting completely different brakes on. Balance could be totally changed. |
29th Aug 2012 10:36pm |
Kev, yes i can make you a set sir... But they are very time consuming and therefore expensive... You need two rear lights as you have to smash the clear cover off one and then cut the plastic away from the rear of the other... Price of 4 rear lights... Labour of about 20ish hours... That said, weve made three more sets for customers since... Craig |
29th Aug 2012 10:56pm |
You also have the issue of ABS sensors being seized, wheel bearings as you normally have to press out the drive shaft therefore having to split ball joints etc etc... Could easily turn into the expensive job from hell! Craig |
30th Aug 2012 10:56pm |
Other than the lines i dont think the other parts are different TBH but worth comparing VINS and microcat FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
31st Aug 2012 10:12am |
Its not a case of the other parts being different, its the other parts are not made to be removed and refitted... IE the ABS sensors can not be removed as they are plastic and either seize in or are glued from factory (like a Discovery 2) so when changing the carrier, the ABS sensor would most likely have to be replaced! And the wheel bearings would and maybe other componants like ball joints (have to remove when taking off the hub to press out the drive shaft) that have a habit of rubbers splitting when you try to remove them... That's before tackling the drive shafts! Could get very very expensive is all im saying... Fine if the customer is happy to pay, parts labour etc etc but as an unknown quantity, it's very hard to quote a job like that... Craig |
31st Aug 2012 11:04am |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2014 |
Also if you are running with MY10 19" wheels then they too won't fit over the larger Brembos meaning that you will have to source MY11 onward 19"wheels |
31st Aug 2012 11:09am |
