![]() | Home > Technical (L322) > towing |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Don't get anything on mine |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
no indicator to say its plugged in or working.. |
No nothing. My Classic displayed a light but nothing on the FFRR |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2620 ![]() ![]() |
You should get the green trailer light flashing with the indicators (assuming your trailer indicators work). |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Mine has a green trailer lamp lit permanently after plugging in (08MY) |
As does my 07MY. I recall that the facelifted ones (with Jag/Ford electrics) do this and the BMW based ones have a light which flashes with the indicators. Both are only to satisfy the trace light regulations. If the light doesn't flash on the older ones it means indicator failure on the trailer, and on the newer ones the green light stays on all the time but the indicators flash at double speed if there is a bulb failure. At least, that's how it was explained to me. |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
You should also find the suspension is locked in normal height, the 'manual' indication light comes on and you cannot adjust the suspension.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
+1 thats my understanding too... Craig ![]() |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I'm currently towing the caravan across Ireland and I have no warning light on my dash. Can't say I've ever seen one 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Got no warning light (05 facelift) however if I remove an indicator lamp on the van I get a warning message. Pluggging the van in also disables the ride height ajuustment and reversing sensors.
05(facelift with MOST) mine stays on all the time towing the van or a trailer with a board connected |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
Get no warning light with mine either as stated will lock the suspension but only if it is in standard height ( when it's in motorway height it will stay that way until it raises it self as normal then will lock the suspension) but I do get the check trailer light warning on the dash when ever I'm towing and turn the engine off but all lights are ok
Dont be hogging the roads Noddy ! ![]() Gone Audi A5 2.7TDI Gone Discovery 3 HSE Gone Mercedes CLK Gone Range Rover 2.5 DSE |
I think it depends on if its an intergrated one or just one fitted with good old scotchlocks as to what effect it has on the car.
