Home > Technical (L322) > how to work residual heat function
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
as per title.
i have pressed the MAX button with the engine off and key out but it seems to do nothing.
does the outside temp have to be below a certain threshold?
does the key have to be in the keylock?
with the engine on, pressing the max button does what it is meant to do..A/C full blast...
thanks 2011 4.4 TdV8 Nara Bronze
Post #140851 13th Sep 2012 8:06am
Have you tried looking in the manual? Shocked Discovery 4 HSE
Post #140863 13th Sep 2012 9:36am
goldsax
yep.
it say ..with the engine off , on depression of the button...will be operative for 15 mins...
on pressing the max button nothing happens..i presume i should hear a vent fan blowing
have you used this funtion before?
cheers 2011 4.4 TdV8 Nara Bronze
Post #140867 13th Sep 2012 10:05am
speedymarktd6
I think the vehicle needs to be at normal running temperature i.e it should work after the cars has warmed up fully hope this helps but i could be wrong onto no6 Range Rover
Everyone needs a hobby
Post #141045 14th Sep 2012 8:57am
goldsax
i have tried the function after the engine has been on a 30 minute trip..fully warm..
but no joy..
do other members not use this fuction at all? eg while waiting in the car while the wife is shopping Whistle 2011 4.4 TdV8 Nara Bronze
Post #141046 14th Sep 2012 9:00am
I just used the timed climate on manual for that Smile
and now i dont have to Very Happy
Easier solution, get rid of the wife LOL!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #141049 14th Sep 2012 9:25am
goldsax
Laughing Laughing
you should have replied to this thread yesterday when it was posted ..
you would have saved me carrying the burden of these 2 problems for an additional 24 hours....
Laughing
will try the manual timed method.....
Post #141051 14th Sep 2012 9:30am
SteveMFr
Site Sponsor
Residual heat is one of those items with... personality.
I've used it on occasion but it doesn't always work. And I have yet to figure out what parameters it would like to have to switch on.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #142665 24th Sep 2012 10:04am
My TD6 did it easily but my Supercharged doesn't which is annoying when you consider just how much hear these Censored give off Laughing
Edit ; mine does work so not sure what I was doing wrong . 2008 MY Supercharged
Post #142774 24th Sep 2012 4:45pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
I used it once, for a couple minutes.
Then I got all worried about draining the battery so I turned it off.
I just replaced the battery last week.
Turns out, the previous owner had installed an undersized battery; I guess to save a little money.
Looking forward to winter, I'm going to use the programmed heat mode to warm her up a bit before I get in..
New battery, what the hell. Jim
2000 NAS HSE
2005 NAS HSE
Post #143098 26th Sep 2012 4:40am
goldsax
i think i have worked it out..
you have to press the max button within a second or two after removing the key..
worked all this week..
yesterday while the wife was waiting to pick the kids up and using this function for 15 minutes....the car battery went dead!!!!!
jump started..
checked the amp output via 735 funtion..that was all right...took it to halfords for a drop test..that was all right..
just a rubish design i guess.....
for such a great motor why could they not just add another second battery like Bentley do? 2011 4.4 TdV8 Nara Bronze
Post #143106 26th Sep 2012 8:36am
Many of us have asked the same question many times, there's so much stuff in the L322 that needs the battery that things like residual heat and FBH just kill off an already struggling unit. Probably just when you need it! Discovery 4 HSE
Post #143109 26th Sep 2012 9:21am
Dolphinboy
I've got a back up battery hooked up in the rear where the removable tow bar normally goes. Seems to do the trick Thumbs Up
Post #143128 26th Sep 2012 12:25pm
SteveMFr
Site Sponsor
Hi Jim!
D'you mean 'Park Heat' - together on the display with timed ventilation? You can activate this with the IIDTool and it will show on the display, but as you do not have a diesel you won't have an FBH. They were an option with the petrol engined cars in Europe. I still don't understand why they never caught on in the US. Great stuff.
I could send you one... Cost is about a grand for the kit and 2 days of install w/o prior experience.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #143153 26th Sep 2012 2:49pm
