Home > Technical (L322) > Park heating
STMVOGUE2010
Park heating
Hi ALL
I have a 2009 FFRR Vogue 2010 model year 3.6TDV8 it has park heating fitted and I have extra remote however, when I press on button I have rapidly flashing amber light on key fob but park heating does not come on. Tried manually setting timer on car and it works okay.
Any ideas?
Post #142370 21st Sep 2012 6:06pm
Tried the fob with a new battery , mine flashes Green I meant to say
Post #142378 21st Sep 2012 6:29pm
Allan
RR2011 User Manual
The remote control LED indicates various states and conditions as follows:
• Illuminates green for two seconds when the ON button is pressed, to indicate that programme operation has been requested. It will then flash every two seconds while the programme is active.
• Illuminates red for two seconds when the OFF button is pressed, to indicate that the programme has stopped.
• Flashes green or red for two seconds when the on or off buttons are pressed, to indicate that the signal was not received.
• An orange LED at any time indicates that the remote battery power is low and should be replaced.
As above. It needs a new battery.
Post #142381 21st Sep 2012 6:46pm
