Home > Technical (L322) > Auxiliary Heating
baldylocks
United Kingdom 2004 Range Rover Vogue Td6 Bonatti Grey
Auxiliary Heating
Evening all
I'm looking for an 02/03 Vogue to use as a winter car and have seen some advertised as having auxiliary heating. I assume this is a diesel powered heater that cn be set to come on prior to using the car? Do all vogues have this or was it an optional extra?
Many thanks
Post #145104 6th Oct 2012 8:15pm
mjdronfield
I believe all diesels have it.
The optional bit is whether you can activate it with a remote fob...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #145109 6th Oct 2012 8:28pm
ikilla2
2003 Range Rover HSE Td6 Stornoway Grey
I have an 03 td6 hse, when I unlock the the car and open the door it sounds like a boiler ignites in the engine bay and continues for about 15 minutes - is this the aux heater?
Post #145110 6th Oct 2012 8:32pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
My car did that when I bought it and the FBH didn't work
I asked the same question and no body's else's car makes the same noise
May be your FBH ECU could be knackerd mine was RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #145113 6th Oct 2012 8:41pm
No, that is the ECU fan in the engine bay wakening up, perfectly normal
Post #145114 6th Oct 2012 8:42pm
baldylocks
So, what should I be looking for on the fob to identify whether it has aux heating?
Post #145118 6th Oct 2012 8:47pm
You will need a different fob
Post #145119 6th Oct 2012 8:50pm
Jr-auto-electrics
A separate fob with on and off if its a pre 06 it's bigger than the key RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #145123 6th Oct 2012 8:57pm
baldylocks
Many thanks, should all Vogues have this or was it an optional extra?
Post #145183 7th Oct 2012 11:40am
mjdronfield
At least on the earlier cars, all diesels had it, but being able to turn it on and off from a distance with the remote, was optional. Irrespective of trim level. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #145187 7th Oct 2012 11:58am
SteveMFr
Site Sponsor
Exactly. All diesels have the aux heater to aid in heating the large interior on very cold days - diesels are just too efficient and don't put out as much waste heat Razz
To have the so called Park Heat function, it needs to have been ordered that way upon purchase or it can be activated by an appropriate diagnostic tool. The Hawkey will not do this. Whistle
Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #145198 7th Oct 2012 3:14pm
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
so without the key fob how does the aux heating work as i have a td6 and anything to get it warmer quicker on the morning would be cool!
Post #145310 8th Oct 2012 12:47pm
there is a timer function in the menu andy... Wink ... - .- -.
Post #145314 8th Oct 2012 1:00pm
andyleeds
so that means that you can programme for it to come on automatically? if you do that will it come on every day on its own even when you arent in it? or does it need the key to be in the ignition for it to work & am guessing below certain temperature?
Post #145734 10th Oct 2012 8:07am
mjdronfield
I'm slightly unsure myself on this bit. I thought it came on to heat the interior up provided its set on the aux heating thing. Not sure if it only comes on once and you have to reprogram it to come on again the next day.
This is without you in it - car all locked up...........
Then I've read it only comes on below a certain temperature - or is that a different feature when its used to help the engine warm up ?
Do you have 2 options in the menu, one for Aux Ventilation, and one for Aux Heating ?
Think I tried it last year and nothing warmed up on mine, but then sometimes when the car is running and its cold, I can hear the FBH running......
Will have to have another look........
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #145744 10th Oct 2012 8:50am
