replacing pcv hoses and valve cover gaskets | |
im replacing the pcv hoses, valve cover gaskets and timing cover gaskets - what else should i replace whilst being busy towards the back end of the engine?
should i replace the following:
- radiator hoses, including O-rings both manifold to large tube and small tube, rear water return hose to heater
- camshaft variable timing solenoid
- intake manifold rear end plate
- what else?
is it necessary to replace the rear end cover of the intake manifold or only the gasket.
