Home > Maintenance & Mods (L322) > [SOLVED] - Rear washer problem? |
I very rarely use it, but tried it a couple of days ago, got a dribble (from the washer!) then that was it.
20th Oct 2012 3:08pm |
The jet on the wiper arm will be blocked up with crud, a poor design |
20th Oct 2012 3:23pm |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
I doubt if it's the jet but more as like the non return valve on the pipe just before the water goes into the wiper.
20th Oct 2012 3:32pm |
Thanks John and Jonno.
20th Oct 2012 3:54pm |
Could be different firmware given 4 years difference between cars. My handbook doesn't say how many squirts, but does say it will give 3 more wipes once the "washing" has finished. Maybe it depends on how long you hold the stalk against the spring for? .
20th Oct 2012 5:48pm |
Just replaced my rear washer arm as the joint had corroded preventing the spring from pressing the arm against the screen and the washer jets werent working properly, I thought it may have been the non return valve as to why i had no squirting however a new arm in position its working fine.
20th Oct 2012 6:48pm |
