Home > Technical (L322) > Getting heat sooner?
If I leave the HVAC on automatic, it will take about 10 miles of driving on cold mornings before it starts blowing warm air. I have found, however, that if I start off with one of the selection buttons pressed (screen, footwells) then switch to automatic, I get heat after about a mile.
Anyone else get this? .
Post #149807 5th Nov 2012 9:21am
never use auto tbh, i like to have it 'my way'.....did get caught by the side vents blowing cold till i realised my centre vent 'scroll' button was set on cold... ... - .- -.
Post #149808 5th Nov 2012 9:23am
I just use park heat on these colder mornings! -1'c on bangernomics this morn!
Seriously though I have found leaving it on auto is best but each person is different Smile On 21'c though it never gets a hot air blast but on 22'c its not long before it blasts out hot air to warm the cabin up and I've found removing the viscous seems to help with this cold weather stuff at the minute as well Smile Warms up quicker surprisingly! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #149813 5th Nov 2012 9:56am
How do you find the temps without the viscous in place? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #149860 5th Nov 2012 3:37pm
Well it seems to warm up a bit quicker but not much else touch wood!
I run with the ac on almost all the time so that fan is kickin in and out anyway to get airflowing into the bay at lower speeds. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #149862 5th Nov 2012 3:40pm
Have you used the hidden menus to see what temps your running and what you were before? I've been temped to do this but concerned with overheating issues. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #149863 5th Nov 2012 3:51pm
I may have used the hidden menu ages ago but not recently.
The gauge is always just a smidge to the right of middle only by about a mm mind if that, and the engine never has caused me concern so far as i do very little crawling traffic type journeys.
Even offroading it seemed fine with most of the days in low range and crawling up and down hills. Mind you there was a good amount of airflow and the engine bay was toasty but never massively so Smile Most steam seemed to come off the brakes and the exhaust when fording or going thru long deep puddles... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #149864 5th Nov 2012 3:57pm
Having finished my journey to work with footwell and face level buttons pressed and turned off the car, I started my journey home in the same state some 9 hours later. 2 minutes into the ride home (at 30mph) I had lovely warm air coming out of the vents. Even better than the aforementioned button switcheroo. ONly a problem if the screen is misted up, but could try with the screen button pressed too, but aren't I just back to AUTO then ? Smile .
Post #150313 8th Nov 2012 11:51pm
maybe yes, but you are manually in control of the 'auto'..... Wink ... - .- -.
Post #150339 9th Nov 2012 9:09am
Shocked Rolling Eyes Whistle
Craig Laughing
Post #150341 9th Nov 2012 9:15am
