Home > Technical (L322) > steering column adjuster.
Page 1 of 3 123>
muffster
2002 Range Rover Vogue Td6 Java Black
Hi folks.
I seem to be collecting problems at the minute!
Steering column adjustment, Up and down is fine but the problem is in and out.
I can hear the motor whirring when i use the stalk control but it doesn't actually move.
The motor sometimes whirrs when i start the car up and when switching off and key removed.
I can actually pull the steering wheel out and adjust it manualy, found this out by accident.
It appears that the motor is not engaging properly.
Anyone had this before?
Strangely the anologue clock has started resetting itself as well.
Sometimes on start up it resets itself to 12 o'clock!!!!
Thanks.
Post #149854 5th Nov 2012 2:56pm
this link is just one of many threads re the steering column...it is a common problem...i hope it helps.
http://www.fullfatrr.com/forum/topic13206....ing+column ... - .- -.
Post #149855 5th Nov 2012 3:09pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
@ Muffster, if you can describe me how to load pictures in the reply, I can show you the part you need, only a handmade screw! Regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #149871 5th Nov 2012 4:53pm
Wheres Mick when someones talking about not being able to get something IN and OUT?!?! Laughing FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #149872 5th Nov 2012 4:54pm
mr meerbush, how to post pics...
click on gallery underneath the fullfatrr.com logo,
on the black banner click on upload photos
click on browse and select your pic from your pc/laptop
click continue 4 times
click on your pic and it will increase in size and have the file info
click on and copy the bb code full size and paste onto your post ... - .- -.
Post #149880 5th Nov 2012 6:26pm
Meerbusch
Hi, you can see the part, what is defect, on Gallery, picture 1/4434, the black part under the t of the word motor, it is not to buy singular, only in handmade-rebuild! Can give you help, regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #149883 5th Nov 2012 7:20pm
muffster
I've read through some old threads and the more common issue seems to be with the tilt mechanism.
My problem is with the in-out!!! (telescopic adjustment)
It feels as though the motor and shaft have become detached and therefore the steering wheel will not move.
Meerbusch, if you could post up some pictures and tell me about the screw you described that would be extremly helpful.
Many thanks.
Post #149889 5th Nov 2012 8:09pm
ebajema
http://www.fullfatrr.com/gallery/displayim...;pos=-6184
This link takes you to Meerbusch gallery picture. MY 2010 5.0 SC Galway green and sand interior!!
Post #149891 5th Nov 2012 8:31pm
Meerbusch
Thanks ebajema, my english is not good enough for send pictures in my post..., it is the little black part, if I get an e-mail adress of muffster in the next reply, I can send a picture to muffster. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #149892 5th Nov 2012 8:42pm
muffster
ebajema
Thanks for your help there.
Meerbusch
Not sure what you mean by the little black part.
I've sent you a PM with me email address.
Many thanks.
Post #149902 5th Nov 2012 9:16pm
Tuts
I believe that the nylon white clip that holds the motor onto the spindle becomes brittle and snaps over time (this happened to mine). If you take off the panel which is the 'ceiling' to the footwell trim you should be able to see it. I fixed mine with a cable tie and it works fine! Hope this helps 2003 Vogue 4.4 V8 Java Black
Post #149903 5th Nov 2012 9:19pm
ebajema
I think what Uli (Meerbusch) is referring to is the Reach Motor text on the picture. If you look directly below the t of the word motor, you see the spindle of the motor going through a black nut (or threaded block) that is slotted into the aluminium frame.
If I understand it correctly the thread of that block gets stripped out over time and although the spindle rotates, the block won't go anywhere as there is no thread to be moved. So that block should then be made from scratch ??
It would be easier if it was the white bracket and some tie-wraps for the fix of course Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #149907 5th Nov 2012 10:24pm
muffster
Great,
Thanks gents, i will investigate at the weekend.
Post #149910 5th Nov 2012 10:30pm
Meerbusch
Exactly, was I said, and ebajema sees, is the problem, the black nut. I have made some examples here for friends in germany, one hour work with black plastic (nylon 12mm) per piece, the official bought also one Wink), the complete steering column costs about 2.200,-euro, only changable complete Wink L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #149917 5th Nov 2012 10:50pm
muffster
Meerbusch
Thank you for the email which you sent through.
Is that part available form a dealer or did you just make one up.
Is it a difficult job to change?
Thanks again.
Post #149972 6th Nov 2012 1:12pm
Page 1 of 3 123>
