Home > Technical (L322) > Check Brake Pads
MarkBrand
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Check Brake Pads
"Check Brake Pads" I am getting this error message every time I start or stop the engine, been happening for a month now, and I have just changed both front and rear brake pad wires with no effect. Neither one was worn to the point they would have caused a error message on the dash, however this is a new problem to me and I wonder if anyone has any pointers???
Post #150248 8th Nov 2012 6:28pm
mjdronfield
I'm not an expert here, never had the issue, but I do understand if the sensor wires have not been fitted back in correctly, you get the message come up..........
Have you double checked they are all back in OK.
You have prob done this...........I'm clutching at straws....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #150259 8th Nov 2012 7:01pm
^^^ +1 ... - .- -.
Post #150266 8th Nov 2012 7:13pm
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
2 things which in the past have created simlar problems for me on brake pad warning
One was a dirty connector at the car end, so i was plugging my shiny new wire into a cruddy socket.
The other was some oil on the connector causing an odd short circuit that was at the strt of a 400 mile journey, beeping at me all the way ! 2011 Stornaway Grey 5.0SC Autobiography
Post #150270 8th Nov 2012 7:26pm
MarkBrand
I will have a check tomorrow for a bad connection in the plugs, apart from that I will just have to get used to the "bong" everytime I stop the engine. Sad Big Cry
Post #150325 9th Nov 2012 2:13am
Most likely a broken sensor wire somewhere in the circuit
Post #150330 9th Nov 2012 7:52am
Re: Check Brake Pads
Did you buy genuine leads of cheapy ones? There could be your answer... Failing that get it plugged in... Never be too careful with brakes pal...
Craig Thumbs Up
Post #150345 9th Nov 2012 9:39am
MarkBrand
Thanks for Your help.... Problem has cured itself! Hopefully my flickering oil light gets the same idea! Thumbs Up
Post #150593 10th Nov 2012 9:09pm
