![]() | Home > Technical (L322) > is it normal to have milky oil in the seperator ? |
| woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259
Hi I have took off my coolant manifold at the back of the engine (4.4 v |
finally managed to get the photo link to work MY2010 TDV8 Vogue Ipanema Sand
right it look like the hose is going to the "inlet manifold end cover" and the other end of the hose is going to the "engine breather seperator" MY2010 TDV8 Vogue Ipanema Sand
Hi there I have discovered that the hose between my inlet manifold end cover (back of engine) and the engine breather seperator are full of mayonaise . it seems the oil and water have mixed some where.
I think its something to do with this, taken from the RAVE, but it doesnt mean much to me??
How are the oil and water mixing ? are they supposed to? maybe they are ? it says something about oil condensing and returning to the sump. maybe the water is from the atmosphere and its supposed to be milky?? MY2010 TDV8 Vogue Ipanema Sand
Hi there ebajema,
If I can satisfy myself its nothing to worry about I wont bother taking off the inlet manifold. otherwise ill whip it off tommorrow and investgate further. really hope it is not head gasket or anything like that. I am erring on the "its normal side" as It seems to be fairly isolated in the areas mentioned above MY2010 TDV8 Vogue Ipanema Sand
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Have a look around the BMW forums. It may just be part of the function of the separator that creates the emulsion or there may be a simple solution. I'd say, a check of the inlet would not hurt (but bear in mind that you may need a new gasket when you take it off as the old ones get damaged easily. MY 2010 5.0 SC Galway green and sand interior!!
Yeah that's the trouble no new gasket to hand . Thanks ill check out the BMW forums as you say . Car is running fine at present to hopefully just normal. MY2010 TDV8 Vogue Ipanema Sand
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Wood
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
+1 ^ plus check out this is the WIKI:
Rob and Gazellio,
There is a diaphragm inside which breaks down. Never bothered to attempt to strip it as it was only about £50 to replace and wouldn't know where to get parts from to overhaul. Just remember to get a new gasket when you change it. If you change the cyclone remember to change the 3 hoses not just the top 2. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
