![]() | Home > Maintenance & Mods (L322) > Looking for someone to stop the water ingress |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
What, where is getting wet? Previously..
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 ![]() ![]() ![]() |
Sat nav and amp in the rear |
Yip, common problem. Have you fitted the official water shedder? Previously..
It's got a plastic cover on, but I want to get it fixed if possible |
It's crazy that the landrover fix is just to put a plastic bag over it! I lost my Bluetooth module with the same problem. I never tracked down the source of the leak. Even wondered if it was condensation drips as there must be a bit of heat in there with all the kit, the weather turns cold, etc etc. I wonder if vents in the access hatch would help?? There's an idea....... Previously..
It's more than condensation, there was bad rain last night and plenty of water on the pastic today, sometimes I think I'd be better with a stand alone head unit. |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
This will sort it |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
^Not funny. My garage actually recommended that to me. |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Check the boot seal first, take it off and look for wear holes.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
@ mrd1990
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
I had the same problem mate, I stripped it all out and got six inch sticky lead flashing and gutter seal and shaped it around the void above the electronics. Havn't got any pics sorry. if you pm your number to me i may be able to explain more clearly. So far touch wood or cloth its been ok. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3233 ![]() ![]() ![]() |
It is probably caused by blocked drain holes, most likely the sunroof. There is oodles of comment here and some pictures, I think the solution was found to be a long rotating wire into the sunroof drain hole or stg. Search should find it. |
@cleughy
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
For what it costs replace the boot seal with a new one to be absolutely sure. Fixed 2 different RR's when I have had this problem in the past. I hate water in cars !! |
