Home > Technical (L322) > Key wont turn
this?
http://www.fullfatrr.com/wiki/Key_stuck_in_ignition
or this,
http://www.fullfatrr.com/forum/topic14442....ion+switch
hope these help.. ... - .- -.
Post #192522 7th Jun 2013 10:37am
Both interesting Thumbs Up
Last edited by Gazellio @ Prestige Cars on 26th Jun 2013 6:08pm. Edited 1 time in total
Post #192542 7th Jun 2013 12:12pm
BBS SPY
Cyprus 2003 Range Rover HSE 4.4 V8 Java Black
This fault is something quite common to me.
I have helped sort this in quite a few case with the same symptoms.
You simply cannot turn the Key.
If you disconnect then re connect the battery you can do so, but only once.
Up until recently the only fix was to replace an ECU, however i now know a much simpler and cheaper fix.
I will put together a how to pos to share with everyone, but in the meantime please feel free to PM me.
ATB
Colin 2003 4.4 HSE
Post #196281 26th Jun 2013 6:06pm
BBS SPY
Hiya all again
I have put a document together a document detailing this problem and the cheap fix.
Here is a link to it
http://www.blackbox-solutions.com/photos/L322lock.pdf
ATB
Colin 2003 4.4 HSE
Post #196875 29th Jun 2013 7:06pm
Good info but....
If its physical steering lock bolt sticking problem how come replacing the steering lock ECU also works as a fix???
Post #196905 29th Jun 2013 9:13pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I think it reads that the bolt is inside the ECU?
Post #196908 29th Jun 2013 9:52pm
BBS SPY
Thanks PaulB
I was not present when George actually replaced the Steering Lock ECU, and did not ask more detail about this, but after doing some further research am now given to understand that the ECU itself is just a part of the upper steering column assembly, which must be replaced in it's entirity.
I have amended my document to better explain this Thumbs Up 2003 4.4 HSE
Post #197018 30th Jun 2013 5:31pm
Thanks that makes much more sense to me now Thumbs Up
Post #197019 30th Jun 2013 5:32pm
