![]() | Home > Technical (L322) > SUNROOF PROBLEM |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
I need to check my Rave Manual, but is there still a manual key under the switch panel, maybe correcting it manually will reset it.
| nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2080
Do they have a anti trap sensor? |
Why not try this?
| speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727
do you mean when you try to open it goes back then comes back forward to close and so on , if so i had this problem and you cannot just reset by holding tilt as it will not work what has happened is as its opening its hitting a soft limit at full open then closing
| AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186
Thanks guys for your replies.Suppose first i try with easier proposal of manual setting.If nothing then i will try to see if i can manage it as per second suggestion of rruk.
