Home > Technical (L322) > Central locking and electric window problem
nikbarber
United Kingdom 2006 Range Rover Vogue SE Td6 Zambezi Silver
Hi everyone,
The driver's door on the RR froze up this week, and my wife snapped the exterior latch cable when she tried to open it. I have now replaced the cable, and the exterior door handle is working fine, but it has left me with a different fault.
The driver's door no longer locks on the central locking, although all of the other doors do. I have checked all of the wires on the door card and the latch mechanism itself, and everything is connected as it should be. I also thought that perhaps I could have bent the lock rod when refitting the door card, but that is good and straight also, and moves up and down manually with minimal force. Possibly related - the driver's door electric window switch pack will now also only open and close the drivers window, and none of the other three, but each one still works using the switches on the other doors.
Any help or suggestions would be much appreciated!!!
Nik. 2005 FFRR Td6 Vogue
1991 Defender 90 200Tdi
Post #156172 8th Dec 2012 8:16pm
nikbarber
Iit turned out to be the white connector on the window switch pack (C2058) which is the one that connects to the BCU and the central locking motors. Even though the connector was latched shut, it wasn't inserted into the socket all the way. All sorted now! 2005 FFRR Td6 Vogue
Post #158493 19th Dec 2012 1:41pm
thanks for the update Nik, most causes like this do end up being the connectors... ... - .- -.
Post #158507 19th Dec 2012 3:42pm
