Home > Technical (L322) > Urgent Help
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Urgent Help
Help
Blower not working so checked fuses as per posts and ordered new final stage resistor.
Now car locks and unlocks seat sets key releases ignition but wount start any idea
2005 early facelift
Thanks
Andy Mine was a blue one! Smile
Post #156380 9th Dec 2012 10:28pm
Gear selector in park? Battery fully charged? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #156385 9th Dec 2012 10:38pm
Move the gear selector back and forward a bit when it is in park. Something might not be engaging correctly. Previously..
Post #156387 9th Dec 2012 10:40pm
Andy3681
Sorry did not explain right dash is dead no warning lights but key will turn radio sat nav etc all ok and seat set to position but i have just had battery disconnected for a bit to reset still no good canit lose key pairing for immobiliser?
Ta Mine was a blue one! Smile
Post #156392 9th Dec 2012 10:49pm
BrianC
Why not try disconnecting the battery again for 5 minutes and try again.
Is there a chance the battery is nearly flat ?
Post #156393 9th Dec 2012 10:52pm
sounds like an under powered battery.. ... - .- -.
Post #156394 9th Dec 2012 10:53pm
Don't think so as its the transponder in the key that does the imobilising I thing an if its unlocking the steering that should be ok. Put your battery on charge and try in the morning. These things have a habit of just fixing themselfs. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #156397 9th Dec 2012 10:53pm
Andy3681
Its had a few good runs as was ok exept for fan until i pulled fuses. Strange there is nothing no warning lights on the dash nothing????? Mine was a blue one! Smile
Post #156398 9th Dec 2012 11:01pm
BrianC
Are all the fuses ok and in properly
Post #156400 9th Dec 2012 11:11pm
Andy3681
Going to have to wade through them in the morning what a crap week ! Should never have touched it fu*k Mine was a blue one! Smile
Post #156401 9th Dec 2012 11:13pm
BrianC
I remember reading on l322.co.uk when he removed a certain fuse he had to be recovered and it needed plugged in to reset
Post #156402 9th Dec 2012 11:14pm
Andy3681
Oh joy only removed and checked the ones listed on here to do with the fan but when i put the 10 amp one back in it stirred the electronics up Mine was a blue one! Smile
Post #156403 9th Dec 2012 11:16pm
Sound like when you have put the fuse back you may have given that system a belt or something. Put on charge overnight so you know the battery is full, and pull the fusee you pulled the first time. In the morning check all the fuse's and replace them. Then put the battery fully charged back on. I would also think about touching both battery cables together first to ensure its fully flat and all ECU's are discharged but I'm not 100% sure that's the correct thing to do. Hopefully someone else will give some guidance on that? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #156404 9th Dec 2012 11:32pm
Andy3681
Re checked fuses and had battery leads shorted together when disconnected Mine was a blue one! Smile
Post #156405 9th Dec 2012 11:39pm
Andy3681
Been on charge all night no change checked instrument fuse (1) thats ok
Any ideas?
Ta. Sad Mine was a blue one! Smile
Post #156415 10th Dec 2012 8:34am
