![]() | Home > Technical (L322) > Heating |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
What does the engine coolant temperature gauge say? If it's hot then I think your problem isn't with the coolant not reaching temperature. |
hempy18 Member Since: 12 May 2012 Location: Newcastle Upon Tyne Posts: 8 ![]() ![]() ![]() |
Sits as normal.
Thinking running it n keep topping up until all air is out the system???? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Try running with expansion tank cap off for a while, may help to shift any air in the system ? (This advice not tested as an OK thing to do, just something I might try, others may confirm or otherwise?) .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
question is ,hows the air getting into the system? ... - .- -.
If you are consistently loosing coolant and there's no sign of an external leak, which can be very hard to find on a hot engine, you have to consider the possibility of a head gasket failure.
Cheers nicedayforit
While you are at the garage it would also be worth asking them to do a "sniff test" of your coolant for traces of carbon monoxide.
Well...ain't head gasket issue. Test done n not at fault!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Sticky, water control valves?
Cheers Northern, will give them a look over in the morning!
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 ![]() ![]() ![]() |
Hi
If you guys download the workshop manual PDF through the Wiki, you will see that the heating system is a number of flaps that direct the warm and cold air in different directions. You may have an issue with the actuators, connectors of actuators etc.
