Home > Technical (L322) > Suspension Air Compressor failure 2005 => ON |
Well my MY05 compressor has failed.
15th Dec 2012 5:50pm |
bummer .
15th Dec 2012 6:10pm |
I know Joe Prices for the motor section alone are silly!
15th Dec 2012 6:15pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
That's defiantly broken! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
15th Dec 2012 7:28pm |
Trying to find another one now if I can at a non silly used price FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
15th Dec 2012 7:55pm |
Looks like a poor quality casting
15th Dec 2012 9:03pm |
Well I think I'll look into it though there is a bush of some sort in it and ill have to find a hawkeye I think to clear the fault code as well FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
15th Dec 2012 9:37pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
15th Dec 2012 9:43pm |
No way! There is a chunk missing as well I think, cleaned the lot out now and the motor housing as there was a lot of metal dust in there which is expected with a low quality electric motor over the long term cleaned all the other bits as well now so all clean an the piston sleeve isn't too worn, its much larger than the older style one and I think the motor is a bit bigger as well. The photos of the older ones from the outside look smaller as well.
15th Dec 2012 9:53pm |
Scratch that , remembered its a weak easily fatigued metal FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
15th Dec 2012 9:56pm |
Well this morning on its only journey SINCE i removed the unit after a few dips in the road the rear finally sank onto the bump stops
18th Dec 2012 2:06pm |
I must be the most unlucky person who turns out lucky in the end!
18th Dec 2012 3:30pm |
Buy a lottery ticket |
18th Dec 2012 5:06pm |
I think i will be doing John, Euro Millions tonight
18th Dec 2012 5:15pm |
