![]() | Home > Technical (L322) > DDE/Glow plug light? |
The older the plugs the longer it takes. To be honest most will go out pretty quick unless ubber cold outside as they will actually stay on for so long after the engine stops cranking and is in run position to aid quicker warm up and smoother idling by helping the diesel ignite |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
The e39 i had used to have the same engine as the td6 and they did go off pretty instantly. There is nothing that can't be fixed with a hammer😜😜
This morning in +5'c it was out in about 2 seconds |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
TDV8 this morning was about 5 seconds
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
I never wait on the glowplugs to go out |
Good practise to wait normally 2-5 seconds on a Range Rover TDV8 |
aneurysm1 Member Since: 12 Dec 2012 Location: burnley Posts: 202 ![]() ![]() |
as long it doesnt stay on too long such as 60 secs it isnt a problem to worry about |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35809 ![]() ![]() |
i always start straight away, tried the 'heat the glowplug' method but found my nav screen wouldnt fire up , why i dont know but it was somehow connected... ... - .- -.
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
The glow plugs are all controlled by a timed relay that "should " supply power to the glow plugs for approx 30 sec which you will hear click off if you are near it on most cars they are under the bonnet and the light is just a rough guide and i would have thought that being land rover they set the time on the light to stay on longer to cover all bases in extreme cold etc. which is why it stays on longer than a BMW car.
About 5-6 secs this am.
Stan I have had the same issue on the last couple of days thinking the worst, but sounds like its just being a ffrr |
