Home > Technical (L322) > Air susp inactive after going through flood !!
Tuts
Recently driven through a flood a few times in the last few days- raised the eas to off road each time (about 1ft deep water) shortly after I got an air susp inactive message, the light has gone out on the EAS controller and it appears locked in normal height.initially it drove ok but after a day or so it is now driving horribly, all over the place with clunks on right turns , also I'm not sure but it may be 'drooping' on the OSF . Any ideas ? My local Indy is still closed
P.S I can't hear any hissing . (But I am a bit mutton Rolling Eyes ) 2003 Vogue 4.4 V8 Java Black
Post #160138 27th Dec 2012 11:52am
Might be worth trying disconnecting the battery -ve terminal for 20minutes, reconnect and then steering wheel lock to lock with the engine running and see what happens.
You might be lucky.
Post #160150 27th Dec 2012 1:12pm
Tuts
Forgot to put that in the first post, have tried that but no luck I'm afraid. Sad cheers for suggestion though! 2003 Vogue 4.4 V8 Java Black
Post #160152 27th Dec 2012 1:49pm
Had this on mine. Went into a suspension limp mode where the compressor stops but the pressure regulator still works so basically if there is a weak point in your system or you drive over rough roads causing it to try and correct the suspension by letting some air out, it will end up dropping like a fart. Mine did this and on the bump stops it was near impossible to drive at anything but a crawl as every stone in the road would cause it jump or jut Sad
You could do with someone local with a OBD scanner to see what codes are up and then a tool to clear the faults like a hawkeye.
Fingers crossed the compressor didn't suck any air in Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160157 27th Dec 2012 2:41pm
Tuts
Oh great ! (Groan) so what you're saying is the OSF strut may be leaking slightly but it's probably not the cause, just noticeable now as the compressor isn't 'topping it up' due to the (hopefully unrelated) error? 2003 Vogue 4.4 V8 Java Black
Post #160164 27th Dec 2012 3:16pm
Probably!! the compressor could have died a death and the slow airbag leak can now be noticed.
So at worst its a new compressor and ideally 2 front bags.
at best its just a fault clearing and maybe a fuse gone Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160167 27th Dec 2012 3:42pm
Andpopse
Has your RR had LTB00077 done ? If not it could be this. I had this happen (its corrosion in the Compressor muffler). I only found the fault after using the ride height change to go through a deep puddle. Maybe worth getting it checked.
Regards
Andy
Post #160180 27th Dec 2012 5:59pm
Tuts
Sorry Andy I take it that's some kind of recall or similar? How would I find out if mines had it done? It's not on any of the invoices I got when I bought the car. 2003 Vogue 4.4 V8 Java Black
Post #160181 27th Dec 2012 6:18pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Might be worth checking the connections at the height sensors to see if they are dry. thats the first place i'd look. especially since it happened after driving through water. could even be the height sensors themselves have let water in through worn seals. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #160184 27th Dec 2012 6:35pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Check for water in the spare wheel well, that's where the compressor is located.
Post #160203 27th Dec 2012 8:19pm
Dolphinboy
+1 MRD.
also, there is a rubber bung in the floor at the front of the spare wheel bay. Check you have one in cos going through deep water could have forced water up this hole and into your compressor, thus causing the fault. you can take the casing off the compressor to see if it is wet or dry.
Post #160222 27th Dec 2012 11:20pm
Tuts
Right, had the spare wheel out and it's bone dry (which is a rarity I believe! ), the rubber bung is still in place. Think I may have to go to the Indy and get him to scan it. I've had a look under each wheel, all of the height sensors appear intact although the wiring plugs look really badly protected from the elements - poor design? 2003 Vogue 4.4 V8 Java Black
Post #160295 28th Dec 2012 2:45pm
Is there no-one nearby with a hawkeye or anything to clear it for you? once its cleared and you give it some time the pump should come back to life Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160297 28th Dec 2012 3:17pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
I agree with wats39, I had the same issue on my old 2003 Range Rover when going through deep water. After a couple of days the height sensor dried out and normal service was resumed Thumbs Up I never found out if it was a poorly sealed sensor or for that matter which one but as the problem always went away I never bothered to worry too much especially as it locked out at normal ride height so could still be driven ok Rolling Eyes
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #160314 28th Dec 2012 5:54pm
Tuts
Thought I would add the result of this - airbag had split after being raised and had dumped all of the air out, result was a new strut was required, has been fitted and all is ok and back to normal now. 2003 Vogue 4.4 V8 Java Black
Post #161872 4th Jan 2013 4:14pm
