Home > Technical (L322) > Trans failsafe Prog
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Trans failsafe Prog
Hi
I know there is a lot of debate concerning this error. I only get it sometimes and only at start up. Once the car is running and there is no error I then move the gear lever even by as little as a mm, forward to back or side to side, I will sometimes get the error. If I do get the warning I have to switch off, shake the lever and restart.
I never get the error once I'm on the move in Drive. Only at start up.
Is there some sort of micro switch at the lever which may cause this error?
Post #160957 1st Jan 2013 1:48pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Battery voltage issue maybe?
Post #160977 1st Jan 2013 4:11pm
RRPhil
If you're thinking it could be a inhibitor switch fault then you should have a P0705 DTC stored in the controller. Might be worth selecting Neutral rather than Park when you start the engine to see if this makes a difference?
Phil
Post #160984 1st Jan 2013 5:13pm
Paulhh
If I put the key in ignition and the car isn't started I can still activate the fault by wiggling the lever. It may be the battery I guess but it does seem more like a loose connection or something.
More investigation required I guess
Post #161056 1st Jan 2013 9:49pm
Paulhh
Still haven't checked fault codes, but if I put the gear shift into Neutral before starting I do not get the trans Fail safe error. I can then move the shift into drive and no further problems until I put it into Park and then get the fault. 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #161635 3rd Jan 2013 6:51pm
drakes
Is this the sort of code an IIDtool can read and reset? 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #221970 10th Nov 2013 11:54am
RRPhil
You have an inhibitor switch fault
Phil
Edit - Oops, hadn't noticed the date - this fault must have been sorted months ago
Post #221996 10th Nov 2013 2:45pm
Do you have a battery charger or boost box? Even though your battery will start the car OK put your battery jump pack on before starting then do the same procedure to try and replicate the fault... If you cannot get it to do it then you know your battery maybe 10% below par Thumbs Up
Should give you a definitive answer about battery voltage Thumbs Up
Post #221999 10th Nov 2013 2:54pm
