Home > Technical (L322) > Diesel smell? |
Most likely be a diesel leak somewhere under the bonnet, should be easy to see |
1st Jan 2013 11:42pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6658 |
Do you mean on the exhaust side rather the feed side? Or something burning off on the hot engine? Got - 2017 SDV8 Autobiography in Loire Blue
1st Jan 2013 11:50pm |
More likely to be the feed side and the heat off the engine makes the smell more noticeable. |
1st Jan 2013 11:54pm |
Would I expect to see any drips on the drive, as I don't have any? Got - 2017 SDV8 Autobiography in Loire Blue
2nd Jan 2013 12:06am |
It only takes a tiny amount to smell it, not enough to drip down to the ground. |
2nd Jan 2013 12:12am |
OK, I'll take a look around tomorrow. Any specific areas I need to look? Got - 2017 SDV8 Autobiography in Loire Blue
2nd Jan 2013 12:15am |
Sorry I don't know the TDV8 engine, look for the fuel lines, fuel filter and pump. Follow along the fuel lines and check for leaks |
2nd Jan 2013 12:17am |
If it is a leak it will probably be tiny so check carefully |
2nd Jan 2013 12:18am |
You could always take up the driveway into Mick's estate and have him look it over |
2nd Jan 2013 12:21am |
Nah, I've heard he shoots intruders! Got - 2017 SDV8 Autobiography in Loire Blue
2nd Jan 2013 12:35am |
Couldmbe to do with the FBH, noticed that it smells quite fumes on mine of recent. More exhaust than supply tho. There is nothing that can't be fixed with a hammer😜😜
2nd Jan 2013 1:40am |
It's been like this on and off for a few months, so the FBH hasn't been used until the past few weeks.
2nd Jan 2013 1:45am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
I also get the same smell. I'm pretty sure its the FBH. It comes on automatically if the temperature is under 15C and does a purge after the engine is switched off if it ran for less than 20mins. This stinks out my garage.
2nd Jan 2013 8:48am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
I would say its the FBH, it kicks in at all sorts of times and the smell is pungent and revolting, a really thick acrid diesel exhaust smell.
2nd Jan 2013 10:06am |
