![]() | Home > Technical (L322) > Various errors gearbox HDC etc - battery on way out? |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Having been thru all this it would seemthat ideally you want the bat to read 12.5v engine off and 14-4-6v at just over idle with everything on, I changed the bat and everything improved on mine but now going for alternator as I never see 14v with it running. Hope that helps, depending on mileage on the alt you could just put a new reg in it for Ł49. One day your life will flash before your eyes......................................make sure yours is worth watching!
HDC Inactive is the first sign of reduced battery power. it is possible but difficult to diagnose that the gearbox message is a result of the same problem, but unlikely once you have the engine running, as the alternator will/should be proviging the correct voltage @ 14.5V. Could just be a gremlin. Looking at fault codes might help, and could be gear linkage issues - have you greased your linkage recently....? .
Spilling Coffee/Drink on the gear-change area is also a good way to get HDC Inactive up..... |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Right , mine is definetly only reading 14v with engine running, may have to look at a new alternator - does anyone know how much labour is involved in changing the alt? 2003 Vogue 4.4 V8 Java Black |
NO food or drink allowed in my FFRR ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
I wouldn't on mine (14.3v <- IIDtool) ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
The 14v is prob not too bad the problem with mine is that on tickover as you switch everything on it dips quickly to 11.9v and rises to 13.8 - 12.9v like its spiking it, thats my theory and im fitting a new alternator next week. One day your life will flash before your eyes......................................make sure yours is worth watching!
