Home > Maintenance & Mods (L322) > Handbrake adjustment wheel seized |
Brake caliper hasn't seized has it? |
17th Jan 2013 4:04pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3064 |
No brakes Are fine. It is also only registering 13% on the handbrake test. Can the cold weather have had an effect? It has been sitting unused for the last 4 days |
17th Jan 2013 4:07pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34939 |
can you not disconnect the handbrake cable to free up the shoes.. ... - .- -.
17th Jan 2013 4:08pm |
They want to take the hub off and look at the shoes! They think that the adjuster may have seized hence the poor jandbrake perfromance
17th Jan 2013 4:16pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
When I fitted my new brake shoes I split the adjuster and lubed it, worth doing if they eventually get hub off. |
17th Jan 2013 4:23pm |
there's a hole in the hub where you can put a screwdriver in and adjust the shoes, i gather they have tried this without success...its best to get it sorted James tbh.. ... - .- -.
17th Jan 2013 4:24pm |
If you had the pads replaced a year ago I would have thought everything should still be free.
replacing pads doesn't affect the brake shoes .. ... - .- -.
17th Jan 2013 4:41pm |
Meant shoes. |
17th Jan 2013 4:57pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
They have the car in neutral? It's not the gearbox holding it? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
17th Jan 2013 7:10pm |
No all the other wheels turned fine - just the rear left was stiff. THink the new Shoes put on for the last MOT have seized somehow, probably due to it not being used very much (have been away for a while).
17th Jan 2013 9:38pm |
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 |
I'd say yea, seems a bit draconian to fail the car on something so trivial , especially as he's the guy that normally MOT's the car & obviously knows that its well looked after. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
17th Jan 2013 9:58pm |
Possible the cog on the adjuster is catching on the spring. A bit of poor design in the drum I feel.... .
17th Jan 2013 11:17pm |
