Home > Technical (L322) > changed the anti roll bar link / drop link today...
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
What a ballache, I had to grind the bottom nut off as it was seized solid. Also I've still got a knocking coming from the suspension . Any one have any pointers where else to inspect I.e . Bushes ? MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #167931 27th Jan 2013 6:30pm
Lower control arm... Thumbs Up Previously..
Post #167932 27th Jan 2013 6:36pm
woodchopper23
How many bushes to that one off the top of your head ? MY2010 TDV8 Vogue Ipanema Sand
Post #167936 27th Jan 2013 6:57pm
It's the ball joint on the end of it that wears and clucks when you hit bumps. Lower control arm or as some call it lower suspension arm, same thing, there is a great write up on how to change it. I was getting knocking on sweeping corners as well, but it was the clunck from holes and speed bumps etc that drove me nuts and made me change them. About £25 a side, easy job.
Looks like this..
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...amp;_uhb=1 Previously..
Post #167942 27th Jan 2013 7:45pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Had a knock from mine too when going over speed bumps. went away when slightly pressing the brakes going over them. replaced both anti roll bar links as they were worn but still had the knock. turned out to be both the ball joints on the front nearside. upper and lower i think they are called but both are on the bottom. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #167954 27th Jan 2013 9:21pm
I looked at doing mine, there are 2 on each side at the front. Upper and lower track control arms.
I spoke to the specialist and they recommended swapping the whole arm rather than the bushes as they come with thrm fitted. The seats for the bushes can aparently stretch on the arms so that they arent a tight enough fit if you just change the bushes. The tca's are about 90 ish an arm. I have a tca bush on my desk as a paperweight hey are about £20 each. There is nothing that can't be fixed with a hammer😜😜
Post #167974 27th Jan 2013 10:28pm
woodchopper23
Thanks for the input guys . I will investigate further and report back... MY2010 TDV8 Vogue Ipanema Sand
Post #168038 28th Jan 2013 10:31am
