![]() | Home > Technical (L322) > Brembos.... |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Just get a cheap punch pin set from bnq or the like as there is a perfect size in most for the brembo pins. Once they are loose they close out easy enough |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Because they are 4 pot calipers you cant get a c clamp on them.
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
Thanks chaps |
Last question chaps seems to be warnings about compatibility are there diff sizes for the 3.6tdv8 that have Brembos mine is 08?
If the technical pic is anything to go by then they are wrong. Should be kinda square.
These might be worth a call if they are "brembo" at that price, it does say should be over 120 notes.
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403
Ribble valley are good... Very good price too |
Ribble Valley are very good and will beat almost any quote i have given them for anything LR related thus far |
Ordered some cos at that price, if they come as Brembos they are a bargain and mine need doing soon. Even if they arent Brembo then they are a bargain anyhow and my fronts still need doing. There is nothing that can't be fixed with a hammer😜😜
I bought Pagid front and rear with sensors 79.00 including delivery.
Pagid are a great make even for standard pads. If you find they wear quicker than you like ask them for their Blue pads |
Did a write up on here on how to do the rear pads.
| All times are GMT |
