|  | Home > Technical (L322) > TD6 water pump change |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | There's a web based version of rave in the wiki. iPad friendly!   | ||
|  19th Feb 2013 10:08pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | I think the part number is PEB000050G | ||
|  19th Feb 2013 10:14pm |
| 666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108      | Thanks
|  19th Feb 2013 10:22pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | I would think the radiator would need to come out to allow access as it's rather tight in there | ||
|  19th Feb 2013 10:32pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | To get at coolant pump looks like same procedure as thermostat, apart from the need to remove the ancillaries belt
|  20th Feb 2013 12:12am |
| 666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108      | Thanks for the help.
|  20th Feb 2013 10:40am |
| 666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108      | Done some more research. The plastic impeller had fallen off as I took the pump of, the metal is from the bearing. 2012 4.4TDV8 VSE
|  20th Feb 2013 10:47am |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455      | If it were me I'd flush the system in both directions and leave it a good 10 minutes each way to do it. Also take the chance to flush your rad out and get any gunk from the bottom out.
|  20th Feb 2013 11:22am |
| 666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108      | Thanks. I have been running a hose through every easily removable pipe to clear what I can. I intend to run it up to temp with water and drain down again before adding antifreeze.
|  20th Feb 2013 8:09pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | The problem is you do need a skinny spanner to fit on the back "holding nut", and you are right, the Halfords fan spanner is just not long enough to get purchase. I bought a proper 32mm (monster) for the nut on the fan.
|  21st Feb 2013 1:18am |
| 666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108      | Our advice then to others is get a decent 32mm spanner, I went into halfords originally to see if they had any. They said they only stock up to 19mm, then the lady said he'd check. She came back saying they had a 33mm one!!
|  21st Feb 2013 10:22pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Interesting, on mine, the "fan nut" was 32mm and oil filter cover 35mm ? .
|  22nd Feb 2013 8:18am |
| Posting Rules
 d the water pump bearing when fighting to get the vicious fan off ?
