Home > Maintenance & Mods (L322) > Heated seat pad
Page 1 of 3 123>
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Heated seat pad
Front heated seat pad has gone and I have spotted a rear seat pad for £12. Does anyone know if the pads are interchangeable? I'm guessing they're not but you never know. I'm talking about the heated seat pad with element that plugs in.
Post #178555 19th Mar 2013 10:50pm
Front seat heaters are built into the leather so are not interchangable... Thumbs Up
Post #178567 20th Mar 2013 12:03am
Rich86
So what's the one on eBay advertised as "Range Rover Vogue 2006 on Front Heated Seat Base Element, HGL500040"? This looks like a pad.
Post #178586 20th Mar 2013 8:16am
http://www.lrseries.com/shop/product/listi...EMENT.html
FRONT SEAT HEATED SEAT ELEMENT
Part number: HGL500040
Applicable Models:
Range Rover L322
Product Description:
Front seat heated seat element.
Buying options
Brand New (Genuine):£28.09
(£33.71 inc VAT)
and
http://www.brit-car.co.uk/product.php?xProd=146815
http://www.famousfour.co.uk/lrparts/lr_page.php?partID=439009
Post #178588 20th Mar 2013 9:08am
Rich86
I'm confused though...some people say there's wire built in to the foam base and that its difficult to replace but your link and the seat pad I've seen would suggest that the heated seat works as an element within a pad and not built into the foam seat base. Can anyone clarify. Maybe I'm having a blonde moment Very Happy
Post #178593 20th Mar 2013 9:35am
Flashman
I think the 2002-2005 seat bases are different to the newer versions. I understood it that the older versions has the heating element built into the leather seat, but the newer versions have separate components. Tom
Current Drive
Previous Drives
Post #178598 20th Mar 2013 9:59am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
+1
Earlier models, pre 2005, have the heating elements stitched into the seat covers meaning a whole new cover is needed costing hundreds. Later models have separate heat pads costing around £35 each.
I wonder if later ones can be adapted to fit earlier seats with a wiring mod...hmmmm.
Post #179298 23rd Mar 2013 12:26pm
Rich86
Certainly would be a cheaper way...
Post #179301 23rd Mar 2013 12:34pm
Deasy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Well since I bought mine, the only thing that has never worked is the drivers heated seat.
This morning I managed to pick up on eBay a drivers seat with working element in the right colour for £30! I'm well chuffed!
Just need to wait for it to turn up now Smile
Post #183706 19th Apr 2013 9:50pm
Rich86
Ah but what year is yours?
The element is built into the cushion in the earlier cars. Maybe yours is post 2005 with a pad inlaid over the cushion? 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #183709 19th Apr 2013 10:13pm
Deasy
It's a 52 plate, so with the pad built into the seat, that's why ther so blerdy expensive!
So a seat for £30 is a bargain Very Happy
Post #183943 21st Apr 2013 7:46pm
Rich86
So is it going to be compatible? Seems like yore fitting the later pad on to the earlier type arrangement? 2009 Vogue TDV8 Nara Bronze
Post #183954 21st Apr 2013 8:28pm
Weejock
Sounds like a bargain to me if that's a whole seat for £30?!
I picked up the seat base elements unstitched from a new seat cover for £40 from ebay and I thought that was a decent price.
I did a bit of diagnostics on my seat yesterday and found my seat back element is also US so deciding whether to bypass it or sort it before I commit to the repair.
Just to add the early (pre 2005) seat heaters are wired in series. There are 4 elements, 3 in the base and one in the seat back (some may only have the 1 element in the base). If only one of the seat elements is open circuit then you get no heating at all. The only important element is the centre seat base as that contains the feedback temperature sensor. It is possible to bypass the other elements and just use the seat base...provided that one is working of course!
Post #183961 21st Apr 2013 9:06pm
Rich86
Jock I saw your earlier post.
I have the classic problem of the drivers seat switch coming on for 4 seconds then going off hence the seat never works.
I suppose could always swap with the passenger side... 2009 Vogue TDV8 Nara Bronze
Post #183967 21st Apr 2013 9:44pm
Weejock
That's the same problem I have with my drivers seat, which points to a faulty element in the seat or an open circuit somewhere (connector or wiring issue).
You can check seat back element and two seat base side elements by removing the rear seat back (where the storage pocket is attached to) and checking the connectors inside with a meter. Checking the actual central seat base can be slightly more complicated depending on what you find with the other elements (if the others work and you measure an open circuit on the main connector under the seat the central base element is US).
I found I had 3 elements US, one base side, base central and back element!
As previously mentioned if the central base element is OK then you can bypass all the other faulty elements and the heating should work. I wouldn't recommend bypassing the central base element and using the others as the central base contains the temperature control feedback, with no feedback the elements could overheat.
Bypassing the faulty elements would be a cheap 'fix' providing the central base element is OK, unfortunately the central base element is probably one of the first to go!
Post #183972 21st Apr 2013 10:33pm
Page 1 of 3 123>
