![]() | Home > Maintenance & Mods (L322) > Bluish Smoke From under the Front |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2712 ![]() ![]() ![]() |
Did you run over wackyjim, who was smoking a big one at the time?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
this is from the wiki and it refers to the td6 but i'm sure yours will be the same,
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
FBH is triggered automatically to help coolant warm-up for quicker cabin heat. |
Either that or explain this scenario to the other half to let her know i really should have a petrol |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
sounds like the FBH Mick, if it is not working and its cold it could still be trying to fire up and feeding fuel to the burner, which isnt igniting properly leading to the smoke.
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
FBH will work at a certain temperature regardless of whether you set timer or press remote.
Well took it for a run tonight and battered its |
Under warranty, but really you need to be sitting down when they give you the bill. They are the best part of £1500 to get swapped. |
With such a short commute it doesnt give the time for the engine to warm through, and the fbh will try to give a boost to the engine coolant temp, so would be running when you start it and when you turned it off, if it were working that is..... There is nothing that can't be fixed with a hammer😜😜
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
Will probably be the fbh. if its def not working then the good thing is its trying to work so will more than likely just be the glowplug. i replaced one on my eberspacher, similar to webasto, and was about £30ish. not an expensive fix if you can do it yourself |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 280 ![]() ![]() |
On a cold day the FBH will come on without your intervention. Not pressing the remote or not programming the timer makes no difference.
Its the dpf soon Martin will promote me to head moderator |
