Home > In Car Electronics (L322) > CD issue
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
CD issue
Coming home from fishing today my CD player would not play the discs, it just kept saying "No Discs" even though the CD cartridge was full with 6 discs in it, anybody got an ideas?
On the other hand i was thinking about using intravee for my ipod etc. what would i need altogether and where would be the best place to get it all from.
thanks in advance Very Happy gone fishin'
Post #182791 13th Apr 2013 6:40pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
You need an Intravee, an Alpine KCA420i, the two leads which come with the Alpine and a 12v to 5v adapter. All available on ebay if you want to save money or from Toys in your car website if you want new items.
You will also need a serial port to USB connector to download software updates to the Intravee - they are about a pound on the bay of E.
You'll probably come across the ten pin / six pin and three pin issue as your car, like mine, is a 2004. It's a simple enough job to re-pin connectors. If this is the case go to your local scrapyard, find a BMW from 2001 to 2004 ish and 'salvage' the connectors from the CD cables in the left hand side of the boot (possibly behind the boot trim).
Then when you have everything do a bit of searching on here for how to re-pin the connectors, get it all fitted and working and then enjoy the delights of the Intravee. It'll change your life! (am I going a bit overboard now??).
Chris
Post #182797 13th Apr 2013 7:02pm
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
Re: CD issue
I had same symptoms a while back - check that the CD changer is not jammed. If it is jammed it will give that error message and be unable to load, but there is an easy fix that worked for me, see thread on RR.net:
http://www.rangerovers.net/forum/6-range-r...med-2.html Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #182798 13th Apr 2013 7:13pm
tap the changer with the top of a screwdriver .. ... - .- -.
Post #182800 13th Apr 2013 7:34pm
andyboy
Thanks guys, I will give it a go and let you know how i get on Thumbs Up gone fishin'
Post #182801 13th Apr 2013 7:39pm
andyboy
Took your advise Stan and gave it a "tap" and it worked. thanks stan, but i think i will get intravee etc Thumbs Up Thumbs Up gone fishin'
Post #182869 14th Apr 2013 12:20pm
Thumbs Up ... - .- -.
Post #182870 14th Apr 2013 12:28pm
