Home > Maintenance & Mods (L322) > My Air Con doesn't work
Page 1 of 3 123>
I have gas , the clutch engages cleanly and the condenser seams un-damaged but,,,,,,,nothing gets cold.
It goes back in on Tuesday but any ideas ? 2008 MY Supercharged
Post #184484 24th Apr 2013 5:25pm
Do you have fans/blowers? (thinking FSR first)
Is it warm enough ? (Not sure on your model but I know on some cars the A/C won't "deliver" unless outside temp is x degrees.)
Do you have diagnostics (e.g. IIDtool) which will give you info on faults / live values ? .
Post #184559 24th Apr 2013 10:13pm
ebajema
Sounds like my previous problem of a few months ago. Could be out of gas or better liquid, but the system has enough pressure to keep the pressure switch activated and therefore the system working. The lack of liquid phase of course means no cooling effect from the evaporation as there is nothing to evaporate. Better get it re-gassed. MY 2010 5.0 SC Galway green and sand interior!!
Post #184588 25th Apr 2013 8:22am
Thanks for the replies so far , to me it does feel like there is no condensing going on but I have had it re gassed twice so Im thinking blocked or pinched plumbing but where and how ? 2008 MY Supercharged
Post #184606 25th Apr 2013 9:19am
the air condenser is right at the front and is easily hit by stones and debris of the road...you could have a hole somewhere resulting in leakage.. ... - .- -.
Post #184610 25th Apr 2013 9:27am
Thought of that as well but it's holding pressure . There just seems to be no clear reason for the total lack of cooling despite everything seeming to work . 2008 MY Supercharged
Post #184615 25th Apr 2013 9:30am
Have you cleaned the TEMP SENSOR ? They get dirty and stop sensing its hot (Don't ask me how though)
Post #184617 25th Apr 2013 9:32am
But if you press the max button you bypass the tem sensor and put the system in to full steam ahead but as i said , zilch Sad 2008 MY Supercharged
Post #184619 25th Apr 2013 9:35am
mmmm
Post #184622 25th Apr 2013 9:36am
ebajema
When you re-gass it this time, let them add that fluorescent stuff. That way you can find out where the leak is. Also last times when regassing, was there any liquid left or didn't they check/tell you ? MY 2010 5.0 SC Galway green and sand interior!!
Post #184630 25th Apr 2013 9:44am
afaik air con gas already has some kind of fluorescent stuff in it and all you need is a UV lamp to see any leaks.. ... - .- -.
Post #184633 25th Apr 2013 9:46am
ebajema
I have only seen it once as it was being added to the AC of my GMC. Very sure here they don't have it in. MY 2010 5.0 SC Galway green and sand interior!!
Post #184637 25th Apr 2013 9:51am
I think you need the car put on diagnostics, preferably Testbook, otherwise you could end up chasing round for weeks and get no Thumbs Up where.
Post #184639 25th Apr 2013 9:59am
Now fixed
Such a simple problem in the end , this really only applies to cars like mine with four zone climate and to be honest I have never heard of another but this means I have my entire centre console full of a second HEVAC unit and when it was re-gased all the gas was drained out the system but when replaced only the front system took the gas . So when I turned on the rear system gas rushed in , the pressure drops , bothe systems stop working due to lack of pressure . Moral of the story keep my rear system on when re- gassing . 2008 MY Supercharged
Post #185914 1st May 2013 9:07am
Thumbs Up ... - .- -.
Post #185915 1st May 2013 9:08am
Page 1 of 3 123>
