![]() | Home > Technical (L322) > Doors wont opne with remote or key |
Flat battery … |
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
just been doing a bit more googling and seems like it - suggestion about getting power to starter motor from underneath the car (its sitting a normal height and I'm a skinny wee runt - so might be able to reach it). Any thoughts? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35814 ![]() ![]() |
..or power through a tow socket ,if you have one. ... - .- -.
mmh - that was my other job tonight as the towing ecu arrived today as well so in future would be an option but not tonight I'm afraid............ flamin typical, came home early to get all these jobs done. Other suggestion on line is the side indicator - got that out without any issue. |
Success with using the new battery, connected to a bit of pared back live wire on the side indicator - left it 2 mins and hey presto doors unlocked with the remote no problem. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Without staying the obvious, just make sure the new battery is a) quality and b) man enough for the job. The electrics on the FFRR are ultra sensitive to strong voltages.
yep - got a contact in local motor factors so he kept me right - still lightened the wallet by £120.00........ |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Also need to find out if there is a fault which drained the battery, or your new one will just go flat and be ruined....
ok - new battery on and everything appears fine - did the left to right full lock and no errror messages and car starts fine - just left it for 20 mins and red led at P is out, safe to assume it is sound asleep? Really appreciate all the help and advice on here |
sounds like a result.. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
hope so - thats the parking sensors front and rear working as well, 2 faulty sensors and a broken wire. Just tow bar electrics, mud flaps and digi Tv upgrade to tackle now, latter might need to wait a bit longer |
