![]() | Home > In Car Electronics (L322) > touch screen nav dim |
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932
I had that problem with mine and dreaded finding out the cost of a new screen. The mechanic updated some software and that sorted the problem. |
| A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973
Mark_j, No. It's uselessly crap. Same system in the Disco. It is incapable of recognising nighttime (or even having a night setting). The two settings you can have are very similar, so it's not worthwhile switching except for brightness levels. I just turn mine off.
The touch screen has a light sensor so does not dim with the light switch, as you can run in the daytime with lights on if necessary and still see the screen...
