![]() | Home > Technical (L322) > cabin is too hot |
There is a flat 4" pipe that runs under the carpet in this area that goes to the rear heater vents under the seats. If your heater is on this will get warm, if you have a lot of excess heat in the cubby box area it could be possible that one of the ducts to the rear blower has become loose. The center cupholder/ashtray should pull out to let you have a look in there and feel around for air flow. ![]() |
RREIRE Member Since: 22 Jan 2010 Location: Cork Posts: 83 ![]() ![]() ![]() |
Did you get it in little island? Blue06 vogue? |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
If you remove the side trim of the footwell (center console side) you will see that the plastic pipe going down gets extremely hot. I think the insulation from the trim isn’t enough to keep the heat away. When I removed the trim last time I put some self-adhesive foam on the pipe and the heat wasn’t transmitted anymore, there was a huge difference between the passenger non insulated side and mine. Maybe this is the solution if the warm trim is annoying… |
yawlboy Member Since: 02 Mar 2010 Location: RAK Posts: 53 ![]() ![]() ![]() |
RREIRE - thats the one - pic in my gallery
