![]() | Home > Technical (L322) > I Don't Believe it - Flat Battery!!!! |
Sounds like a new battery as you say. |
I used the pre-heater for 30 minutes every morning throughout the winter and its starts first turn every time. Get a new battery and have the charging circuit checked if the problem persists. The correct battery in good condition can cope with ALL you can throw at it. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
People sometimes forget when they take delivery of their car that's it's not been used much so hasn't been getting the charge it needs, and will have been moved about the dealer forecourt all the time, unlocked, locked, power up, power down etc but no distance or time covered.
elbitrevnoc Member Since: 17 Mar 2010 Location: Berkshire Posts: 150 ![]() ![]() ![]() |
Oh well, all sorted!
Use the pre-heater its great and works fine. If it does not then your battery is not right and it needs replacing. |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
Take it for a long drive. Do this often if you only normally travel locally, else get yourself a CTEK to keep the battery topped upand in good condition/ Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD! |
Thanks. I normally do 150 miles a day. Did that yesterday, so we'll see how I get on. |
Wow that's a long commute! Would not fancy your fuel bill just for getting to work ![]() |
That's the same as my commute, difference being I don't have to do it every day!
Cracked it! Thanks, RRUK you are the truly the master, the Obi Wan of remotes. This has been driving me nuts! |
I'm not sure about the red light, maybe the remote is defective after all and needs replacing? I can't check my own cos the car is down in Solihull being trashed no doubt by the grease monkey technicians.... Discovery 4 HSE
That's what I said on the other thread! ![]() I'll get me coat now! ![]() Seriously, I thought mine was fooked too, then bothered to read the manual - all became clear ![]() ![]() |
As they say, it's all in the delivery! |
Hmm, I may need to refine my technique ![]() |
