![]() | Home > Technical (L322) > Passenger side mirror stopped dipping |
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 ![]() ![]() ![]() |
For some reason, the passenger side wing mirror has stopped dipping when I select reverse. I have checked that the mirror selection switch is set to "driver" side, so I know that's not the problem. I can see it is dipping a little bit, but doesn't dip fully to enable me to see the kerb, as it used to.
GreenBlood Member Since: 26 Feb 2013 Location: South West London, Surrey Posts: 84 ![]() ![]() ![]() |
Have you tried adjusting it down so you can see the kerb when it is in the dipped position? If you don't get stuck then you are not trying hard enough.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Could just need the dipped position re-entered in the seat memory. |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
I wonder if there are sensors or something inside the mirror. I set mine up when I first got the car and no matter what I select or set or store, my passenger mirror does move when I engage reverse but just moves in small amounts all over the shop. Looks like it's having a fit of some sort. Kinda twitching all over the place.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
this might help,
Thanks for the info guys. It seems very hit and miss at the moment - it didn't work yesterday, but this morning it did. And it still dips ok if I adjust it manually, so there's no obstruction that I can see.
Battery reset will help |
Thanks Craig - will give it a go |
Mark.abersoch Member Since: 23 May 2013 Location: Wirral Posts: 148 ![]() ![]() ![]() |
Did you sort the problem?
Thanks for the tip Mark, but I knew about the mirror selection button needing to be set to the right, and it always is. So that wasn't the source of the problem.
It was worth a try. I didn't know about it for a while.
Is the adjust switch on the right side? Moving the adjust switch over stops the dipping (thanks Stan)...... |
Gaz.... already covered off in my previous posts |
