![]() | Home > Technical (L322) > Air con question |
You need to gas it , make sure they tell you how much comes out compared to how much they put in it might tell you something . 2008 MY Supercharged
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 ![]() ![]() |
Ok cheers, kwic fit the place I'm guessing by the past posts? |
One of the cheaper options, but doesn't necessarily mean they know what they are doing! .
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
I am pretty sure the first light signifies the system is on.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Everytime you press the "auto button" the AC light should illuminate as that is the default programming... If the AC light does not come on every time then you may have further issues to resolve after the re-gas... They also cannot re-gas it if the light does not come on as the system needs to work whilst final filling ![]() |
Thanks, I got in the rr to come home and the system was on auto straight away, the a/c light came on, drove not even 50yrds and it went off again? Weird! If the blowers are flat out(full speed) and I press the a/c button i can hear the speed fluctuate but no light? |
Then i would say you need to sort that issue out first... Maybe your heater panel playing up????? |
Ok cheers, anything I can do about it? When I get in the car literally I can here a gurgling behind the glove box, I checked the a/c fuses think three ish? One was 30a when I took that our the gurgling stopped put it back in as it was fine, started up again? |
