![]() | Home > Technical (L322) > battery drain? |
STEV8 Member Since: 02 Nov 2012 Location: essex Posts: 35 ![]() ![]() ![]() |
going away for a couple of weeks-battery drain likely?if so can i lock the car without activating the alarm?any suggestions welcome 05`V8 AUTOBIOGRAPHY |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
I don't think so. I think there is a way to deactivate the passive inside (maybe double click remote from memory, but handbook will say.
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 ![]() ![]() ![]() |
I don't use mine much so I'm going down the solar powered battery saver route, as I'm sick and tired of finding an almost flat battery when I do come to use the |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Another vote for the solar battery charger. Plug it into the boot accessory socket as that's on a permanent live. Si. <This is my name.
Just a case now of deciding which one gives the best results! This one has a good review on Amazon:-
Well, solar charger arrived and is plugged in. Before connecting it, a reading with a voltmeter put the battery at only 12.1v, but after 30 minutes of "solar charging" it is already up to 12.35v! |
If it were skinnier you could have put it on the sunroof blind between the sunroof and the blind and just left it there all the time and then tucked the cable into the headlining a bit like the solar sunroofs some cars now offer |
Just been out and tested your idea and it does fit. |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
So assuming it's up front as you suggested where did you plug it into. I thought the up front cig lighter sockets have no power when the ignition key is out? Ash
It's plugged into the front lighter socket and the socket definitely works when the key isn't in the ignition. |
Glad to have been a help to someone |
Should have mentioned, I have put it back on the dash for the time being, until I have the confidence to pull apart the headlining and windscreen trim! |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
^Bosch S5 110AH |
I wish I had invested in a Bosch S5 too (mines an Alphaline 100AH from Performance Batteries - it's complete |
