![]() | Home > Maintenance & Mods (L322) > 4.2 Supercharged Idling Rough |
| Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261
Mine burbles nicely on tickover and I worry not one bit.
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
It does Si, most days, only about 10 miles covered.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
It sounds like you may have a fuel issue, i.e. dirty fuel or water in the fuel. Mine is super smooth (granted I had the entire fuel delivery system changed thanks to a cheap fuel pump on Ebay) following a complete clean of the fuel tank, fuel system and inlet tract.
Hi, the fuel tank was on 1/4 this morning when the symptoms were present.
If it is the famous 1/4 tank issue, then the dealer will have to sort it out. And the fuel pump at "normal" price is quite "stiff", in the 300+ range !!. Mine was 50 thanks to Will spotting it on Ebay |
What's the 1/4 tank issue? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
this might help explain,
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Some dealers do still have some in stock but few and far between at such prices |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Seems to only really effect Supercharged models...
Possibly due to the higher fuel flow required but the TD6's have had the odd one fail as well in this way as its the balancing part that burgers up!
That's really helpful thanks...
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
Sometimes when you start it the viscous fan can be partly engaged and give the effect of the engine racing, mine does this quite often, it's nothing to worry about - my guess is this is what you / your wife has noticed. Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
The viscous coupling may be getting on a bit if its doing that i would think. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
| All times are GMT |
