![]() | Home > In Car Electronics (L322) > Separate fuse for front lighter socket? |
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 ![]() ![]() ![]() |
I thought that all the cigarette lighter sockets ran off the same fuse in the cubby hole in the boot, however, I've checked fuse No.71 (20a) and it's fine and the middle and rear sockets both work but the front one doesn't. It was working ok on Friday but stopped yesterday after a few days of running my new solar trickle charger on it! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
try something else in the socket to make sure its that that has gone. ... - .- -.
OK - can someone explain this?
12volt sockets and ciggy lighter sockets are slightly different... ... - .- -.
Not sure I understand you Stan. In what way are they different? Just to clarify, I am putting the 12v air compressor in the front ciggy lighter socket and it works, but when I put the ciggy lighter itself (which belongs there!) in the same socket it doesn't. But the lighter works in the socket behind the driver's seat.
i think its to do with the depth of the socket which will [if shallow] activate the ciggy lighter but wont in a deeper socket...hope that makes sense... ... - .- -.
Ah, I see. That does seem to ring a bell from a problem I had a while back on an old Discovery.
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
I'm sure they are on different fuses anyway. I found out that just one of the four cabin sockets were working on mine (left rear). The rest were off. I fund a dud fuse in the boot box which will have hopefully fixed them all. (I forgot to check |
I wonder if it's different on later models, as the manual for the earlier L322 clearly states only 1 fuse in the boot cubby hole. Cheers
