![]() | Home > Maintenance & Mods (L322) > help please |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
Not a good sign if it has oil in. Prob head gasket. You should top up with fresh coolant and inspect for leaks. Check that there is no water in the oil(looks like mayonaise in the oil cap). My Previous RR's!
mjrp Member Since: 21 Jul 2013 Location: Uk/Sweden Posts: 16 ![]() |
Hi
bluearmy Member Since: 20 Aug 2012 Location: lancs Posts: 22 ![]() ![]() ![]() |
hi no overheating not pressurising no mayo it looks like bayles the drink im wondering if its the oil cooler thats part of the gear box how do i check gear box oil to see if the oil has mixed |
Well, if your dipstick is clean and the oil level hasn't dropped then it is entirely possible that your oil cooler is to blame, I haven't worked on a L322 so can't give you specifics on the gearbox level I'm afraid, I'm sure someone will be along to help you soon. I know some are sealed so there is likely to be a level bung half way up the casing but I'm just guessing.
thanks for you reply i hope its the cooler but dont think this is going to be a cheap fix |
Ebajema has had issues recently of this nature. Might be worth a PM to him for advice. This thread mentions the work he did
