Home > Technical (L322) > Help non starter .((
Needle
2003 Range Rover SE Td6 Java Black
Afternoon all , Roy the rangie is giving me grief so im hoping someone can point me in places to look please, it wont start and just turns over , but if i spray easy start down its throat it starts ? but its coming up with fuel injector fault on the display .. blah .( 2003 TD6 , any advice guys ,thanks in advance Bow down
Post #201269 28th Jul 2013 4:38pm
adigorn
Intank Unit cankered Big Cry
the fuel pump inside the tank is dead Thumbs Up
Post #201270 28th Jul 2013 4:46pm
One of the two fuel pumps have failed... Check the wiki as this has been covered many times on the forum Thumbs Up
Post #201281 28th Jul 2013 5:49pm
adigorn
The remote one doesn not give inj fault message
Post #201284 28th Jul 2013 5:55pm
Needle
so the general thought is its the pump inside the tank thats gone ?
Post #201314 28th Jul 2013 10:40pm
No, the pump in front of the n/s rear wheel. remove the cover and hit it with a spanner and it should come on for a few miles
Have a read at this thread
Post #201316 28th Jul 2013 11:05pm
Needle
thank you Thumbs Up ,will try that tomorrow .))
Post #201317 28th Jul 2013 11:07pm
It may well be an injector. I had exactly the same issue and it was an injector not the pump. The pump seems a very sensible place to start though.
Post #201331 29th Jul 2013 7:40am
Needle
mmm ok so i just went out side and opened the panel , switched the ignition on and u can hear the pump running,runs for about 15-20 seconds then shuts down. it sounds like you can hear diesel getting pumped back into the fuel tank ?
Post #201347 29th Jul 2013 10:56am
Needle
just changed the pump with a new one still a non started without easy start .((... leak off test next then .. how much is acceptable as leakage on these things as a matter of interest ?
Post #201402 29th Jul 2013 5:52pm
Fame
Portugal 2002 Range Rover Vogue Td6 Java Black
Same as Kurt, my one injector had packed up. Range Rover Vogue TD6 2002
Defender TD5 90Hard Top 2001
Range Rover Classic TDi 1994
Mercedes Benz 1959 220S Sedan
Post #202147 3rd Aug 2013 8:54am
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
had the same fault a while back, turned out to be the immobiliser ews fault .
try re sync the remotes. have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #202182 3rd Aug 2013 4:33pm
adigorn
when shes already running (after easy start) do you still getting injection fault displayed?
Post #202244 4th Aug 2013 9:45am
