Home > In Car Electronics (L322) > TV in motion.
Mph28mph
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
TV in motion.
Hi am trying to sort the tv in motion out.
I have a 2002 non touch screen nav and I have bought a lead but I am unsure where to plug it in, is it into the tv module or the nav CD player.
I have sorted out my av input and rear view camera just need this lead sorting.
Thanks in advance
Post #202849 7th Aug 2013 6:40pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Re: TV in motion.
It's illegal and stupid. Don't do it.
Post #202861 7th Aug 2013 8:04pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
+1
Post #202862 7th Aug 2013 8:09pm
supershuttle
I keep forgetting that I have TV facilities at all even when parked up Whistle
Same with the music, got my iphone all wired up - never use it Confused
But I am a Radio 2 on the move man Rolling with laughter Geoff
Post #202872 7th Aug 2013 8:57pm
Mph28mph
It's not illegal to have a rear view camera wired up chaps or are I missing something, if in reverse will the screen still work?
Post #202881 7th Aug 2013 10:05pm
Welshdragon
old thread I know,
Im have got a rear camera which records ( mini dash cam with RCA plug) and for it to work through the head unit when on the tv av channel, but would I need the tv on the move module?
I have the cable mod ready and the camera works only in park hence the question, but I might of answered it by just fitting a switch for it to turn on and not go through the reverse connection on rear light and tv channel button. Confused
Any ideas? If it dont work.......burn it!
Post #277242 23rd Aug 2014 5:26pm
If going through tv av on the tv module then yes you will need to activate TV in Motion for it to work when not in park. Can't remember if you need to if you are wired into the reverse cam av on the tv module though. A switch makes sense, then you can watch out the back anytime!
I have my reverse cam setup through my carpc, just a matter of selecting on the screen. (In process of revisiting carpc with the leaps and bound in Android) .
Post #277249 23rd Aug 2014 6:56pm
Welshdragon
Cheers Tim Bow down
Cheapest way to go is relay and switch then Very Happy If it dont work.......burn it!
Post #277251 23rd Aug 2014 7:25pm
Yes, 'cos you will need Navcoder or posh diagnostics to set it. .
Post #277253 23rd Aug 2014 7:29pm
I used to do this with a TV in motion lead - the one I got had a aux video in - I used to run a camera behind my trailer where I had a fairly large blind spot from the mirrors
Post #277273 24th Aug 2014 6:59am
