![]() | Home > General > Got an hour to kill! |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2622 ![]() ![]() |
11k |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Sorry to hear that David. I hope they get it sorted for you |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
err, Jason...2013. |
Nice one Jim
there was a new post Jason, it was trommels , who resurrected this old thread.. |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
^^ Jay got one on order...but in 2 minds whether to go for it, been running around in an old Jeep which has done me fine and I have actually had a demo of a new Jeep GC which I really liked. Was thinking if I went for the Jeep what I saved on a Range Rover I could put towards another XKR which is a car I would like to get again just for the burble of that 5 litre V8 |
I do like the look of that new Jeep, but will it fall apart quicker that a FF. XKR is the dogs |
Your maybe right about the Jeep...had an XKR before and still have an XKR reg number on retention would be a shame not to use it!! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
its possible to temporary fix the stuck/non working starter fault, without any real tools. you will need to raise car if poss. and crawl a little under to the bellhousing, (ie your arm and head behind front wheel etc.) find the starter motor main unit. the solenoid will be bolted above to it. with a brick (or a hammer if poss,) even the wheelbrace, give it a sharp tap or two. then try it. then try again a few times. it may free the stuck solenoid slider, or clean up the electrical 'spark' carbon on the contact plate- to energise it. the motor is about 4 inches across and about 8 inches long. it might get you going instead of waiting for a recovery. -for him to do similar! don't ignore it after though. it will return!
Reminiscing again, in the old days, you just undid two bolts removed starter sprayed the bendix with WD40, got it moving nice an freely (having cleared out the crud), pop it back in and away you go |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 301 ![]() ![]() ![]() |
must be a week spot, a mates 4.4 TDV8 is on it's thrid starter motor now, all under warranty! 2011 Range Rover Vogue 4.4 TDV8
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3330 ![]() ![]() ![]() |
Well almost a year after the starter motor was replaced at 4500 miles, it's started to do it's clicking and not starting again at 9000 miles.
