Home > Technical (L322) > Big improvement after EGR valve removed
Andy
I've fitted the blanking kit finally, having had it for months in its box. There is a noticeable difference now and I can only assume by looking at the valve I took off, that it was u/s.
The car picks up quicker now, accelerates better, pulls through the 50-70 section better. MPG is around 21 around town. It had dropped to 17 and no matter how soft I drove it, I couldn't get it back to the 20's.
Might get a mild remap done now!
Post #208149 5th Sep 2013 7:57am
did mine and have always been a fan of the blanking kit... Thumbs Up ... - .- -.
Post #208152 5th Sep 2013 8:03am
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
how long did it take to do, i have seen the thread on the wikky but whats the real life experience?
Post #208153 5th Sep 2013 8:03am
Andy
Start to finish with no interruptions, I reckon it'll take anyone with average ability half and hour tops.
It's only 4 bolts holding it on. It's just removing the covers to access it that add to the time.
Post #208157 5th Sep 2013 8:17am
May I ask which kit you bought Noddy?
Post #208178 5th Sep 2013 9:09am
@Andy, this mod is one of the few that actually does make a difference..it allows cool air in which makes the engine run better... ... - .- -.
Post #208197 5th Sep 2013 9:48am
ebajema
Or you do what Stan did, trade the TD6 in for an SC. Makes a lot of difference in hp and torque Twisted Evil Twisted Evil Twisted Evil MY 2010 5.0 SC Galway green and sand interior!!
Post #208198 5th Sep 2013 9:50am
..but it did cost a bit more Eugene.. Laughing ... - .- -.
Post #208200 5th Sep 2013 9:51am
Can this definitely not be done on the TDV8?
There seems to be conflicting stories as to wether it can or can't........... Got - 2017 SDV8 Autobiography in Loire Blue
Post #208229 5th Sep 2013 10:38am
Andy
I bought it off eBay. The company name escapes me at the moment. I'll do a bit of digging later and find out
Post #208325 5th Sep 2013 4:34pm
i've not heard of it being done on the tdv8 Alan... ... - .- -.
Post #208327 5th Sep 2013 4:47pm
plumajp
United Kingdom 2004 Range Rover Vogue Td6 Oslo Blue
why dont people just pull the vacum hose off the EGR body and bung/ plug it, then the EGR does not operate and cool air flows into the inlet manifold. thats what i did to mine and it took 15 seconds, no removal of covers, just a cheapo interior screw i had lying around my nut and bolt tin.
Post #208465 6th Sep 2013 12:01pm
Pulling the vacuum hose off and plugging it is fine but how do you know the egr valve is closed to the gas recirculation port?
Without checking beforehand for all you know the valve is stuck open to the recirculation port and therefore removing the vacuum hose does nothing, exhaust gases are still going into the inlet manifold.
Post #208470 6th Sep 2013 12:08pm
plumajp
if its jammed open, then surely a fault would show on OBC.
if you suspect it maybe stuck, you could undo the one clip holding the intercooler pipe onto the EGR body and peek inside. squeeze it back down with flat head screw driver. add an extra 10mins
Post #208472 6th Sep 2013 12:11pm
The egr valve on a TD6 is a mechanical device only with no electrical input/output which is why it can be removed in the first place, its performance can't be monitored with a diagnostic tool.
As for checking the internals and levering the valve into the closed position, have you ever seen the inside of one of these valves that's been on a car for a few miles? I shall leave that to you. Thumbs Up Very Happy
I honestly think for the cost and time involved in replacing the egr valve and so getting a definite result, doing the job properly is the only way to go.
Replacing the valve also has the additional benefit of ensuring a clear path for the inlet air flow not restricted by the valve mechanism and build up of carbon/oil deposits.
Post #208476 6th Sep 2013 12:29pm
