![]() | Home > Technical (L322) > Suspension Fault Max Speed 30mph |
Chapeau! Velo Member Since: 22 Jul 2019 Location: Down South Posts: 115 ![]() ![]() ![]() |
A really helpful read as my 08 L322 suspension is behaving in exactly the same way. Great pointer for me to discuss with the indi tomorrow (who to be fair will probably be all over this!) |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 262 ![]() ![]() ![]() |
Unnecessary quote removed
West 4x4 in Bishops Waltham |
Any update? 2011MY 4.4TDV8 Autobiography Baltic Blue
Of course! A simple fix; a new front drivers side suspension strut owing to a leak / split in the old one. Essentially the compressor was working overtime to keep the system full of air owing to the leak and shutting down when it got a bit hot. All good now. |
Thanks for the update. Was your front corner sinking overnight? Still trying to get to the bottom of my issue - intermittent faults are the worst! 2011MY 4.4TDV8 Autobiography Baltic Blue
The whole car would sink when stationary and engine off, not just that corner, presumably owing to all the air in the system escaping via the split. |
Fred Member Since: 04 Nov 2021 Location: Fermanagh Posts: 1 ![]() ![]() |
I have the same suspension problem, can you send me detail of your repair guy
Eventually got to the root cause of my 'cross-articulation algorithm' fault - replacing the n/s/r height sensor has done the trick. Odd that it did not come up with a specific height sensor fault code though. 2011MY 4.4TDV8 Autobiography Baltic Blue
