Home > Maintenance & Mods (L322) > annoying fan squeal when opening door. SOLVED |
If you remove the horizontal panel above the foot pedals you will find an electronic sounder that gives out the "boings". I would try unplugging the sounder to eliminate it as the cause of the sound you hear. |
16th Sep 2013 9:49am |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 332 |
Check the e-box fan, located in the depths of the e-box on the LHS of the engine compartment. It keeps all the electronics cool during high temperatures.
16th Sep 2013 10:21am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
well, after advice from this posting, i heard the fan squeal again, and thinking it WASNS'T the under bonnet brain box, i hunted and hunted for that noise. eventually i opened the bonnet, and thumped the ecu brain-box, and hey presto, it stopped! later that week, i read up on changing it out. but seeing that it costs around £200 i thought i would try something DIY. i got it out and all it is, is a small 12v motor, a quitesmall squirrel cage fan, and a small printed circuit board. -around £20 worth at that. i removed the guts, and after prising off the cage fan, and pulling motor, i felt that it seemed not to spin, (in my fingers, -but it turned, like it was running dry so i wd40 the bearings, lightly, and immediately it seemed to spin, (in my fingers) so, i put in a small drop each end of 3in1 oil. i spun it a few times, and it semed better. reasembeled and it seems to be fine now. it used to squeal every few days, and its been good now for a week, but i will report back if still happens.
8th Oct 2013 11:07pm |
Good tip and fix .
8th Oct 2013 11:24pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
8th Oct 2013 11:40pm |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 |
Now.......
9th Oct 2013 7:58am |
when my car made the noise, it would do it as i opened the door, and i would hear nothing for about 1-2 seconds then the squeal, so it wasnt doing it while 'asleep' at least i assume so. -also, whilst this has been going on, i have not had any battery isues. though i did whack in a new bosch 5 year supersize, after about one month of ownership, as i have come from p38 ownership, and this seems the only way to know you have a proper battery to start with.
9th Oct 2013 11:27pm |
